Claude A. Moreau
Thread starter- Joined
- Aug 13, 2005
- 6
I bought a couple of 1987 Merc outboards a year and a half ago and they are just about driving me crazy. Unfortunatley. I bought them sight unseen, having been told that "they run great and are in good condition" <br /> <br />I had the carbs overhauled, the fuel pumps rebuilt, new impellers...etc. before installing them. They have never run properly, but I manage to use them anyway,and have put a few hundred hours on them.<br /><br />Every time I use them the same two problems occur. They run reasonably well for two or three hours, then all of a sudden,both motors go into some resembling a "limp home" mode. The port side motor will run, as long as I don't rev over 2800 rpms, and the other one doesn't rev over 2200 rpms. If I give even a tiny bit more throttle to either motor, it will quickly stall out. They will rev up and peg out in neutral, but not under a load. Usually this problem will eventually go away later in the day, but not always.<br /><br />The other serious problem is that at some point after the above problem occurs, The starboard motor always will die out. I can easily start it up again, but it will only run as long as I keep pushing in the key button (choke?). <br />this problem used to go away after a while, but now I have to do it all the way home every time. This is a major pain in the ***.<br /><br />I have figured out that my main problem has to do with a dissruption in the fuel flow to the motors. I have eliminated all sources of fuel supply problems outside of the motors, and am conviced that the problems are occuring internally. I had the carbs checks out professionally, and they apparently are not the problem. A mechanic suggested that water may be getting through the engine cowling and getting into the carbs (our waters are usually pretty choppy), but I am not convinced that is so. <br /> I am unable to talk any local mechanics into going, out with me to diagnose the problems, so I am appealing to you guys for any ideas.<br />Mahalo (thanks)
