#1 and #5 plugs fouled - others clean
ZmOz
I've only been able to run my new '72 1400 powerhead on the muffs for a few minutes as of yet. I'm running 25:1 oil mix for breakin, so I expected the plugs to be pretty dirty. I replaced them today, and #1 and #5 were pretty fouled, but the others were quite clean.<br /><br />Does this mean anything?
LubeDude
Re: #1 and #5 plugs fouled - others clean
Did they look like they were firing at all?<br /><br />I would check to see if you have a good strong spark on those cylinders, and then take it to the lake and see how it runs. Then when you get done, check them again and see if they are fouled again.<br /><br /> :p :p Hey, dont forget the oil when you go to the lake. :p :p
ZmOz
Yes...I think they were firing. I've been using the #1 plug wire to do the timing, which I had to do a couple times, and it worked fine the whole time. "Fouled" might be a bit excessive...they're just much dirtier than the rest - completely covered in black, while the others still have alot of clean white showing.
LubeDude
Glad to hear your almost on the water again. :)
timmathis
berak it in a little more. Make sure it dont get to hot. like lube said break it in a little more and then see what you got. Tim
ZmOz
Ok, after about 2 minutes running with the new plugs, here they are:<br />#1<br />
<br /><br />#2<br />
<br /><br />When I remove the #1 plug shortly after running alot of smoke pours out. Cause for concern, or am I just being too paranoid?
Dunaruna
Looks like the #1 plug is not sealing 100%. Look at the washer. There is also arc marks on the body, it's not grounding properly.
ZmOz
Originally posted by Dunaruna:<br /> Looks like the #1 plug is not sealing 100%. Look at the washer. There is also arc marks on the body, it's not grounding properly.
No, it's sealing fine, it just looks that way in the pic. I don't see any arc marks either. :confused:
ZmOz
So, nobody thinks I should be very worried about this? Is it possibly a sign that the #1 cylinder may be overheating? I had some water flow problems in the beginning, still not completely sure they are solved....
LubeDude
Originally posted by ZmOz:<br /> So, nobody thinks I should be very worried about this
Evidently not, Its more important how they look after a few hours with a good load on the engine than how they look in a tank. two miutes probably isnt really enough for the engine to actually reach any type of operating temp. Seems all plugs never look the same on most any engine I pull the plugs on, car or boat, new or old.
timmathis
Zm, Probably Ok.Like Lube said 2 min would be hard to tell anything. I would run it at least 15-30 min and then check again. You also may want to pull your distributor cap and see if any arc marks in it. Let's Hope and pray it will be o.k. Probably Just a little extra pre assembly lube left in #1 & #5 Is what you see.
timmathis
ZmOz,On your cooling issue.A little tip here on inlines. You can take a longer hose(Your pee line)and route it up and over #1 and back down and out your pee hole.(that way you can be sure it is geting water to all 6.) The way they are set up all you can tell is that the bottom 3 are cooling. Tim
snappernz
you can also do a spark plug test<br />when out on the water but 2 minutes at idle will tell you nothing at all
Mixtli
I have the same Merc 1400, mine was sitting for about a year and a half or that is what they told me. I got plugs and got it started it smokes like a chimeny though. Tim on your tip about routing a hose can you explain it to me in more detail is the pee hole the tell tale? Me newbie sorry.
timmathis
Mixtli, Do you understand now?, Tim
