water in the # 6 hole
dakk1
1985 Merc 150hp XR2 V6<br /><br />Well, the hits just keep on coming with this motor. Checking the condition of my plugs after running the motor on muffs tonight, I found milky white on #6. What are the possibles here? Crank seals? Head gasket? Any and all responses welcome.<br /><br />Dave..
gss036
Re: water in the # 6 hole
The most obvious would be the head gasket. Do a compression check if you are able to.
quilter
I just tore down a 1995 200 with the exhaust gasket burned out. motor was ruined because it had been happening too long. water was comeing through exhaust # 6 cylinder.
quilter
dakk1
Just did a compression check on all cylinders and compression has gone up in #6 to about 130, all others about 110. I guess this would rule out the head gasket..<br /><br />Dave..
