Wow, it runs! Inline 6 videos...
dakk1
Re: Wow, it runs! Inline 6 videos...
Stan<br /><br />I love it when a plan comes together. What's your break-in pocedure? How long on the 25:1? I may be following in your footsteps soon. Oh yeah, who are all those shady characters in your video? Just kidding. :) <br /><br />Dave..
stant1man
Im planning on running 100 litres on 25:1 then go straight to 50:1. Im sure that will be sufficient...<br /><br />I pulled the plugs and ran a quick comp test, it has only ran for 20 minutes at idle so the rings will be far from seated yet...<br /><br />1 - 129 / 2 - 122 / 3 - 125 / 4 - 127 / 5 - 127 / 6 - 122<br /><br />Bottom plug was "very" clean in compared to the rest though I could see no water droplets at all, why would this be? I fitted new crank seals in the bottom, surely not the exhaust plate again.... arrgggg freekin out..<br /><br />Also played with the timing and in order to get it to advance to 5 degrees after TDC for "timing event one" I had to adjust the distributor plate all the way, is this normal or am I a tooth out?<br /><br />Thanks Again<br /><br /><br />Stan
Clams Canino
Bottom plug seees a bit more steam in general, even without a problem at all.<br /><br />-W
stant1man
Is it normal for the bottom plug to be clean like that then? <br /><br />I ran it for about 30 mins on 25:1<br /><br />Just worried that a problem is still there....<br /><br />Stan
jheron
I agree with Clams don't worry about it :) <br />If she starts drinking water you will probably notice it on the other plugs as well ... at least on mine I did on 5 and 6 and mine was hardly leaking. Get out there and get some hours on her! :) :) <br />Jon
Clams Canino
Ya... don't be worried.... my #6 plug is always clean too. <br /><br />And the process for a pre-emtive strike and actually fixing a resultant problem are almost 50/50. <br /><br />-W
OperativeK
Man I missed the videos!!! Please repost. Ill host them if you want. Just let me see. Also if anyone else has videos please post. Just wanting to compare.
Nos4r2
They are working now.<br /><br />Sounds GOOD Stan!
