I have a 2002 (Ok the emissions sticker on the engine says 2002 and boat is an 02 but the engine tag says 2001) Mercury 115 ELPTO on my Nitro fish n ski. <br /><br />The Problem - (Im still new with outboards so bear with me) everything runs awesome until we throttle down after running the engine for a spell (5 - 10 minutes at around 3500 RPM). When we throttle down going into a no-wake zone or to pick up a skier, the engine runs very rough and almost always dies in idle. When I put the engine in neutral, and try to re-engage into idle speed, the engine dies. Once the engine dies, it will restart but die again when we engage the prop - sometimes it will even die without trying to put it into idle speed. It does not occur when I disengage the prop (keep in neutral) while giving gas I am at a loss of correct terms since Im still relatively new with an outboard.<br /><br />The only way for me to get past this problem is instead of putting the boat into idle speed, I get it started and give it lots of gas from the start.<br /><br />Things I know about the problem:<br />1. Doesnt matter who is driving<br />2. Only happens when the engine is warm (run at higher RPMS over a period of time)<br />3. Typically only happens when you engage the prop to go into idle speed<br />4. Engine shakes and runs rough (kinda shakes the whole boat!)<br />5. Engine runs around 750 RPM<br />6. Engine sticker says the idle RPM in gear is 650 (that seems way low since it dies at 700-750)<br />7. Cold it idles out of gear around 750-800<br />8. To keep the engine running, I have to 'throw' it into gear (basically very briskly - I mean VERY - put it past idlespeed and very slowly throttle back to idle speed- keeping the RPMs higher)<br />9. It has cost me one alum. prop from drifting into the bank and the prop hitting mud ok thats just something Im bitter about (trolling motor battery died earlier that eve)<br /><br />I also would like to find the appropriate service manual for this 2 stroke engine (My wife bought me a 4 stroke Mercury book I love when she tries)
