guardian mode question..
ctoolman
once a opti goes into guardian mode do you have to clear the code after fixing the problem???or should it just take care of itself...
timmathis
Re: guardian mode question..
ctoolman, I'm not sure on that. Someone will be along soon that can answer that for you. Are you the snap-on man? iboats has been a good tool for me.I'm down here in death vally. see ya,Tim
ctoolman
Tim,i am the cornwell toolman that runs in simpsonville/mauldin/white horse road area...been there for 12 years..
timmathis
Keep bumping it somebody will help soon I'm sure.^ Bump sign, Tim
CounterRotation
If your engine went into guardian mode and you shut it down and corrected the problem, it will restart and run normally. The code will remain stored in the EMM until someone attaches a DDT or CDS and clears the code.
ctoolman
Originally posted by Dave R.:<br /> If your engine went into guardian mode and you shut it down and corrected the problem, it will restart and run normally. The code will remain stored in the EMM until someone attaches a DDT or CDS and clears the code.
thanks...not the answer i wanted since that means they(dealer)didn't fix it..... :confused:
