Old Mercury problems..
hunter991
I have a 1964-65 Mercury 20 hp outboard. I think it was the Merc 200 made by Keifer.. i just found out i have scored cylinders and it won't run correctly. Is this thing worth fixing? I am not sure what scored cyl are. Or should it be junked?
Chinewalker
Re: Old Mercury problems..
Hi Hunter,<br /> Scored cylinders are generally considered to be "bad", but not necessarily fatal. However, unless you are willing to do the work yourself it will probably be better off becoming a parts motor for someone else. Scoring is when the normallyt smooth sides of the cylinder bore become gouged, either through wear, overheating, improper timing, or improper fueling. <br /> It might be as simple as some light scuffing of the cylinder walls, in which case a good honing and a couple of pistons and rings might bring it back to life again.. Not hard to find either the pistons or rings (same as those used in the 50hp up into the early 1990s) but the cost involved may be much more than you feel the motor is worth.<br /> It could be as bad as a catastrophic failure of a piston due to an overheating. In this case you might need to bore out the cylinders to oversize and install oversize pistons. This would be very pricey, indeed.<br /> If the motor has sentimental value, then you might be more apt to put more into it. If you're just looking for a mid-size kicker, park it and save it for a rainy day project. It certainly won't hurt to tear it down and take a closer look. It's already "broken", so you're unlikely to break it more. Could be a fun learning experience!<br /> Incidently, there are lots of similar motors out there missing lower units. Mercury used a lot of carbon steel in their lower ends which were prone to rusting. This works for you in that there are lots of otherwise good upper parts out there to serve as "donor" motors should you decide to tinker with your motor. A simple powerhead transplant might be all you need to get it back among the living.<br /> Parts and manuals can be had at several sources, including here on iboats, and www.oldmercs.com. <br /> Good luck, and for the record, it's "Kiekhaefer", as in Earl Carl Kiekhaefer, the founder of Mercury.<br />- Scott
hunter991
Thank you, that was a fantastic explanation. I am very mechanically challenged so this motor may be divied out for parts.
Chinewalker
Hi Hunter,<br /> Another option may be to gift the motor to a less "mechanically challenged" son, daughter, neighbor kid, neice, nephew, etc. who may have an interest to be sparked. I know that the generosity of a few neighbors who knew I was "that kid who likes to take stuff apart" helped fan the flames of the interest initially sparked by my Dad. Helping a kid put the GameBoy down and pick up a wrench might be the best thing of all!<br /><br />- Scott
SeaKaye12
Chinewalker...<br /><br />I've read enough of your posts by now to get a feeling for the man behind them; the two posts of yours above are a good example.<br /><br />You are the sort of person I would like to meet someday.<br /><br />Thanks for your help to all of us here in iboats.<br /><br />Chuck
hunter991
I agree, i was surprised at the fantastic posts above. Great forums reflect on their members.
