SeaKaye12
Thread starter- Joined
- Jul 3, 2005
- 1,116
Well...I've posted about this before...<br /><br />I have a 1977 850 with a tach that "redlines" whenever the ignition is turned on.<br /><br />(I already checked the ground connections that fixed the problem for another poster)<br /><br />I plan to disconnect the existing wires at the tach...and run "test" wires (to help figure out if there's a short or other issue in the harness somewhere)<br /><br />So...If I run the black to the battery -terminal...the white to the battery + terminal...and the brown to the rectifier.....that should be it; right?<br /><br />I know that the white should be 12V only when the ignition is "on"...but for my test I assume that hooking to the battery is OK?<br /><br /><br />What do you think it means of the thing still redlines? (ignition on...but engine stopped)<br /><br />My engine runs fine...battery charges...do I then assume that the tach itself is bad? And if so...are they servicable? I doubt there can be much inside of one.<br /><br />Thanks folks...I really appreciate it, Chuck
