Re: Merc 7.5 gear oil change
My engine is a '74 9.8, but I believe the following applies to any 9.8 or 7.5 with a flush hole. My owner's manual states that the flush hole is only to be used with the engine NOT running. My understanding is that the water circulates through the powerhead, but not necessarily through the waterpump itself - at least not enough to lubricate the impeller. Therefore, if you run the engine, it has to be in a tank (conventional muffs don't work because of the way the pick up is located.).<br /><br />By the way, you can get an original owner's manual (as well as shop manuals) from mastertechmarine.com. I got original manuals for both of my old engines (OMC and merc) and I find them handy because they give you general maintenance and operation guidelines that are not in the shop /repair manual.<br /><br />As for draining the water for winter storage. Any outboard will drain completely if it is kept in a vertical, non tilted position for a just a few minutes. After that you can tilt it for winter storage. I happen to leave my outboards vertical for storage though, which is probably the most fool-proof way to do it.
