lower leg removal!
gss036
Re: lower leg removal!
Wal-Mart and Shucks Auto/Auto Zone all carry it down this way. Maybe Canadian Tire or another auto parts store. You guys had a lot of trouble getting SeaFoam there until peole started asking for it, maybe that is what it will take.
AMD Rules
Tim,<br /><br />I just happen to have the exact motor ('87 50hp) in my garage right now, separated into 3 pieces (lower unit, mid-section, and powerhead).<br /><br />Holding the lower unit on, is two nuts (visible on each side), then the trim tab bolt, and beneath the trim tab you should see two nuts. That is a total of 4 nuts, plus 1 bolt.<br /><br />The drive shaft is splined into the bottom of the crank shaft and <should> slide out by hand. There is also a spline on the shift shaft in the lower unit. If either of them bind, you're going to need to follow the advice that has been presented above. Do you boat in salt water? How long has it been since the lower unit has been off?<br /><br />I can take pictures to show more detail, if you need them. <br /><br />Idea: You can confirm that it is not the shift splines that are stuck by disengaging the linkage up under the carbs. There is a small nut on the linkage hinge that can be removed to separate it for the test. Then you can then try to lift the shift shaft up by hand a bit to make sure it is not binding. Normally you would not have to undo anything up top at all.<br /><br /><br />Rod,<br />I have not seen PB Blaster up here (yet).
AMD Rules
Btw, that serial number shows up on the Merc site as a 70/80/90hp motor. Sure that is the correct serial number?
pine island fred
Up date on mine. It went on the street. Turned power head up side down and partually removed the rubber seal at the spline. Tried all sorts of penetrating oil, occasional tapping and rapping. Home made slide hammer attached to the shaft. Nothing worked. Age and salt water I guess. Hope you have better luck. fred
Moody Blue
"It went on the street"<br /><br /> :eek: Oh no, you didn't toss the entire motor did you? Could have sold it as a parts motor on iboats here or on e-bay or parted it out and sold the individual pieces. Its not still sitting out there by chance? <br />Too bad things didn't work out for you on this motor, they seem bullit proof (not corrosion proof it seems ;) ) and a great little motor. I really like mine.
pine island fred
Yep, disapperare yesterday along with a whole mess of roofs, carports, siding and other metal debris in the neighborhood. What a mess! Offered it to the local merc dealer but he declined it as to old. Wanted to give parts away but ran into difficulty as it is against i boat rules to post like that ( I suggested shipping ) Might still be able to give the tilt unit away as i will also pay shipping. As long as someone can use it. Never been much into selling things. <br /> Got my electric back last night, Sort of miss all those generators screaming in the neighborhood , including mine. Boy they are wonderful things to have. regards fred
saumon
Hi fred,<br /><br />like i told you in the "power trim swapping" post, i send you an e-mail at stinkin_badges@yahoo.com <br /><br />Is the address right? Oh yeah, i'll take it for sure. Tanks again.<br /><br />Steve
grp44
Fred I live just up north of of you if you still have the trim and tilt I would drive down and get it.<br />Mike<br />813-920-4835<br />grp44@yahoo.com
MrBigStuff
Originally posted by RodC:<br /> Has anyone in Canada ever seen this PB Blaster. I have looked everywhere for it and no luck :(
It's interesting how the name got switched around. So many people call it the way you did. It's actually B'Laster PB. No problem cause it's common enough now that most people know what you're talking about. I started using it many years ago and was an immediate convert. Looks like something advertised in the back of Popular Science (next to the XRay glasses) but it really does work.<br /><br />The company is B'Laster and the product is PB Penetrating Catalyst. Here's a link to their web site http://www.pbblaster.com/store/ follow the links to buy the products on-line.
AMD Rules
Its no wonder people get the name mixed up ... look at their website url for heavens sake. :)
Moody Blue
Thanks for the clarification Rastro. This product has been referred to often on these forums simply as PB Blaster. Guess we know why now :rolleyes: I'm going to try and order some but I'm not sure they will be able to ship across the border.
