Help needed wiring switchbox.
mg_dragon
Need help with wiring for Merc. model 110 9.8 hp. serial# 3927452. Colors on new part don't match old original part. New part is CDI 114-6222. Any help would be appreciated.
Laddies
Banned
Re: Help needed wiring switchbox.
Red and blue are stator wires, brn and white are trigger wires grn to 1# coil and grn/white to 2# coil
mg_dragon
Thank you for your reply Laddies, but this part has more wires than that. I think i have figured out some but not all.<br /><br />Blue + Blue/white --- to coil<br />Green + Green/white --- to coil<br />Red --- to stator<br />Black --- to ground<br />Brown --- ???(trigger?)<br />White --- ???(trigger?)<br /><br />The first 4 are similar in color to the original part, but the last 2 aren't. The original has 2 brown wires that go to the front of the motor to a junction to the left of the carburator. They appear to be trigger wires, but which one is which?
Laddies
Banned
The connections by the carb are trigger wires and if you have them wrong it won't hurt anything the engine just will kick and not start and you can rev. the wires then to make it run. What brand is the switch box?
mg_dragon
Thanks Laddies. I now have fire at both plugs. Going to re-clean carburator just in case and see what it will do.
