Motor problems
Pastor Mark
I put a new bulb, plugs and checked all connections. I am getting fire to all the plugs and plenty of gas but it won't fire at all now. And won't start<br /><br />Thanks Pastor Mark
WillyBWright
Re: Motor problems
Welcome to iboats. :) <br /><br />First things that come to mind are a problem with fuel tank ventng, or more likely the fuel pump needs to be rebuilt. Easy job, cheap parts. Rare combination when it comes to marine repair. ;)
JB
Re: Motor problems
Could also be an air leak in the fuel lines. Check that first.
Re: Motor problems
When the engine begins to act up, squeeze the primer bulb a time or two. If the engine picks up and runs normal, you likely have a fuel pump problem. If that doesn't help, I'd look toward the carbs (assuming you've done the obvious tank vent, bulb, hose, checks).
Rockonafly
Re: Motor problems
Also check the check valve in the squeeze bulb. The outlet check valve came out and bounced around the bulb. The motor failure was intermittent. I found it after replacing the gas lines and rebuilding the fuel pump. If it is out you will feel a small object inside the bulb. The bulb/ line can be replaced or disassemble bulb to reinsert the check valve.
Pastor Mark
Re: Motor problems
Originally posted by Pastor Mark:<br /> I put a new bulb, plugs and checked all connections. I am getting fire to all the plugs and plenty of gas but it won't fire at all now. And won't start<br /><br />Thanks Pastor Mark
Pastor Mark
Re: Motor problems
Hey, everyone thanks for your help. I got it running great now. I owe you all a big thank you!<br />It was dirt in two of the carbs.<br /><br />Pastor Mark
Pastor Mark
Re: Motor problems
