Inline 6 Bleed Restrictor re-installation
MercFan
Hi guys!<br /><br />Pulled the motor off the boat last week-end inorder to build up the transom by 1 inch.<br /><br />As I lay the engine on it's back (Spark plugs down) a small rubber insert fell out of the cowling. It's about 1/2in. in diameter and steps down to about 1/4in. Has a very small hole through it and a slight indent on the 1/2in. side. I believe this to be a bleed restrictor? The symptoms matched those of an engine with some/all missing bleed restrictors.<br /><br />I read that they go under the inlet port covers, but I just want to confirm exactly where that is, and what has to be removed to get there.<br /><br />Looking at the engine from the rear, is it the big cover on the left hand side behind the throttle lever? Do I have to pull the power head to get to it? Or can I drop the bottom cowl and get in there with a ratchet and socket? Should I be expecting any other loose parts? If I have to pull the powerhead, what's involved? What do I take off and what can I leave? Anything I should take note off as I'm removing it? What can I check while it's off?<br /><br />Thanks in advance! :)
Clams Canino
Re: Inline 6 Bleed Restrictor re-installation
It's not a bleed restrictor you found. And the cover you're refering to is on the exhaust (wrong) side.<br /><br />-W
MercFan
Thanx Clams!<br /><br />What did I find? Is it important? Any idea where is goes?<br /><br />So the inlet port covers are on the fuel pump side? They have little heat fins on them?
Clams Canino
I have no idea what you found... without a pic.<br /><br />And yes the intake covers are on the fuel pump side.<br /><br />-W
MercFan
Will take a pic in the morning and post, thanx for all the info again mate :)
timmathis
Sounds like a motor mount. That is the first thing that I thought. Need Pic like Clams said..Tim<br />P.S. It a little small for a mount I think. It can be hard to play the guessing game.<br />A pic will tell real quick.
MercFan
Here's the pics of the little fella<br />
<br />
<br /><br />Any advice on what it is and where it came from will be much appreciated<br /><br />Thanx guys!
gewf631
That sure looks like a rubber shock absorber for the cowling cover (or something similar).
Clams Canino
Yannno, It might bee too early in the morning, but I can't place it on 1st sight. I agree that it looks like a rubber shock damper for cowling parts.... but I can't say "Oh it's THAT one"<br /><br />Any takers?<br /><br />-W
timmathis
That is what my guess was a motor mount shock absorber Etc, But I think it is to small for that.<br />I have seen lots of things fall out of a outboards no telling what you may find in one. Tim
MercFan
Thanks guys!<br /><br />Atleast it's not a working part then :) <br /><br />My guess would be some part from a neighboring yamaha or something.<br /><br />As long as it's not from my engine I'm happy :) <br /><br />Thanx again for the inputs :)
