USING PWC OIL IN PLACE OF OUTBOARD OIL.
sandbass
I USED PWC OIL INSTEAD OF REGULAR OUTBOARD OIL. wILL THIS CAUSE ANY PROBLEM FOR THE SHORT TERM OR LONG TERM. IS PWC OIL ACTUUALLY A HIGHER QUALITY TWO CYLCLE OIL.
JB
Re: USING PWC OIL IN PLACE OF OUTBOARD OIL.
BAD idea, sandbass.<br /><br />Any oil not rated TC-W3 should be avoided.<br /><br />Please don't post all caps. It is viewed as SHOUTING and is hard to read.
sandbass
I DON'T NEED SOME BOOKWORM ADVICE. about the obvious. What is the answer to the question.<br />Which oil is better and what is the differenc. Please dont shout.
BillP
WhAT JB seZ is RiGhT. MoST PeOpLe sHoUlD UsE anY OIl THat iS TcW3 CeRtIfIeD. YoU, hOwEvR, mAY wAnT tO KeEP RuNnINg pWC OIl aNd sEe wHAt hAPpEnS tO yOuR MOtor.
Clams Canino
Any oil not NMMA certified as TCW3 qualified=BAD. That simple. We don't own a refinery to explain the difference. In the short haul it prolly hurt nothing. <br /><br />Now go and sin no more against the Cods.<br /><br />-W
JB
That attitude isn't going to get you much help here, sandbass.<br /><br />If you are going to insult the helpers there won't be any.<br /><br />In the long term you will probably trash your engine. Quality is not the issue. Suitability for the application is the issue.<br /><br />Short term? Well, we don't know how long you used it. You might have gotten away scott free. . .and maybe not.
