Re: need tach for merc 650 - magneto no stator
It should have a stator. Find two yellow wires coming from the fly wheel area. They will connect to the rectifier. The rectifier will have the two yellow wires plus a red wire connected to it. Connect a wire to either yellow at the rectifier terminal. Run the other end to the signal post on the tach. Set thoe tach for 12 pole/6 pulse. If you don't have a stator, but have electric start, I don't know what to tell you. How do you recharge your battery while you are driving on the water?
