lugnutzz75
Thread starter- Joined
- Jan 9, 2006
- 8
is the any advantage or disadvantage to havin a riveted boat welded??
It seems to me if you weld an already riveted boat, it wouldn't be surprising if a lot of the rivets worked loose and then you would have hundreds of leaks. Even if you weld the seams on the outside and the inside you still have the rivets to leak. Why are you asking?Originally posted by Ric M.:<br /> is the any advantage or disadvantage to havin a riveted boat welded??
