Arkapigdiesel
Thread starter- Joined
- Apr 14, 2006
- 22
Re: '99 Merc ELPTO 90 HP electric primer choke
Can you please post a link to the topic. Thanks.
If it does idle too fast, I'll adjust it back.Originally posted by Upinsmoke:<br /> Interesting! That idle speed adjustment should not have fixed the starting problem if you were using the fast idle lever properly. It does the same thing. However the engine may now idle at too high an RPM and create problems in the lower unit.
Well, I didn't know how to use the advanced throttle properly until last night. After realizing how it works I now realize that it would have fixed my starting problems, and it has fixed my starting problems.<br /><br />By the way, I moved the screw on the main carb linkage back to the original location. I now have a great running boat on startup and while skipping across the water!!!Originally posted by Upinsmoke:<br /> Interesting! That idle speed adjustment should not have fixed the starting problem if you were using the fast idle lever properly. It does the same thing. However the engine may now idle at too high an RPM and create problems in the lower unit.
