fishingdan
Thread starter- Joined
- Feb 12, 2005
- 1,045
I have replaced a number waterpumps in various mercury engines over the years (8 or 10???). The latest was in a used 1982 Merc 150 that I picked up last fall. As the procedure dictates, I put the engine in gear and changed out the pump. <br /><br />After reassembling the leg, the lower unit will not go into gear. I plan to take it apart again tomorrow for analysis, but any thoughts on what could have happened? I have not had this issue in the past.<br /><br />I am also only getting a trickle out of the telltale. Plenty of water is pumping out of the prop exhaust when running and the temps seem normal. I suspect the telltale line has some blockage.
