Mercury 115 Will not go over 2200 HP
dtazz
I have a 1981 115.<br />Was running fine on the lake the other day, until al of the sudden no power. Was running at 5000 to 5500 rpm, I stopped and started again, would not go over about 2200 rpm. New plugs, cleaned Carbs, and replaced fuel bulb prior to this problem. Like I said it was all the sudden, thought maybe it over heated and started to vapor lock. Took it out today and right off the trailer it would not go over 2200 rpm, sounds like it's missing runs really rough. In Idle I can rev it to 5000 rpm no problem. Don't worry I don't leave it there for any period of time, so the problem only exists when under load. Any suggestions would be greatful. Thanks
Laddies
Banned
Re: Mercury 115 Will not go over 2200 HP
Sound like you have lost either a switch box or one side of the stator. Ck for spark
Clams Canino
Sounds like high speed stator winding went south.<br /><br />-W
dtazz
Is there anyway to check the stator? IT's still charging.
Laddies
Banned
The stator has 2 functions one is to charge the battery while the other is to furnish power to the ign. system . It may me tested with a OHM meter (not very acurate) or a DVA, have you either available to you? If so we can help with specs.
dtazz
I have a VOM.
dtazz
Oh and how would I check for spark at high speeds under load, how would I check the switch box's
dtazz
Just checking in to see when someone could answer this again. Thansk for the help so far.
Clams Canino
Tomorrow... I have the flu. :( <br /><br />-W
dtazz
Oh ok , Hope you get to feeling better.
Chunder06
You could of run over a plastic bag, blocked water intake and cooked your motor.
Clams Canino
Disconnect all stator wires. If it has a black ground wire leave it connected.<br /><br />Blu-red = 5400-6200 ohms<br />blu/wht - red/wht = 5400-6200<br /><br />red-ground = 125-175<br />red/wht-ground = 125-175<br /><br />There ya go... also do a compression test - just to be sure.<br /><br />-W
dtazz
Yeah didn't run over a bag still have a strong water flow.<br />Well do the check, I will let you know what comes of it. Thanks
dtazz
well I found that my impeller was totally wasted, was nothing left of it, but I could have sworn I still saw water coming out. <br />Tested the stator but I'm not sure of the readings, going to get a different meter and see what it says. But have to replace waterpump anyway.
dtazz
Blu-red = 5400-6200 ohms 6300 <br />blu/wht - red/wht = 5400-6200 6480 <br /><br />red-ground = 125-175 157 <br />red/wht-ground = 125-175 133 <br /><br />Is that alright if it is high? Or is that bad?<br />Don't have a compression tester will have to check around.<br /><br />Could this mean it's a switch box?<br />Or is it becuase of the water pump. Still haven't replaced, going to order it tonight.
dtazz
clamscanino you out there....
dtazz
Anyone out there who can help. Or am I dead in the water.
check compression before you go any further.
dtazz
Ok, replaced the water pump, went to the lake ran around and fished and played, was running fine then all of the sudden same thing happened again, loss of power, I going along and it just started slowing down to around 2200 rpm again. This is just to starnge for me. And there was plenty of pee coming out, so the water pump is still doing it's job. Any ideas?????????? Cause I'm out of ideals.....:/
jaymasta
try pumping the bulb when it starts to slow down, or when you have it floored at 2200rpm, and see if it goes up at all if so it might be the fuel pump or carberurators.
