What is the normal temperature supposed to be when squirting from the pee-hole? Flushed mine out last night for 10 minutes after use in saltwater and the water stayed cold. Good strong stream though. Does the temperature vary from time to time?
What type of engine? Most not all tell tails bleed from where the uptake tube from the water pump connects to the power head. This case there is no change in temp. Others bleed from near the discharge into the exhaust jacket.
