Re: 75hp merc no spark on 3-4
got new stator on now problems have gotten worse. won't idle/r's not stable. backfires /quits. when it does idle it's rough /misses. O.K. carbs are clean/pump is good,but bottom carb if i move the air,rich-lean seams to have no effect. top carb, if i move it i can tell it is working right. timeing 4deg atdc at start- is that right/ max 27deg btdc. is that right [sticker is gone] i set with a light. what should it be at 1000/r's idle. My kids boat, she don't have $$$$ to replace everything that could be wrong. i need to isolate this problem
need to add it does have a good spark on all 4
it will trigger my timing light. have 120-125 psi on all 4
