Re: 1963 Kiekhaefer merc 500 No Spark!
Ok, lets try again, the mag. does not require power to operate, it is grounded to shut off(its the thing that turns back and forth that the plug wires come out the bottom of) it is belt driven the belt come out from underneath the flywheel and is timed to the engine (is the belt there?) If so and the drive wheel on the mag turns you should have spark no spark disconnect the 2 wire from the ground stud and try again, no spark, remove the 2 bolts that hold the plate that has the idle stop and spark advance screws on DO NOT TURN THE ADJUSTMENTS, remove the 4 bolt that hold the mag to the mag tower, gently lower the mag (it has a blind spline so it will only go on 1 way) with the mag lowered remove the mag. cap (2 screws)carefully it's over $100 next remove the ground wire from the cap support, remove the mag from the engine and the other 3 screws and its all right there, PIECE OF CAKE
as you can see you really need a manual there are no short cuts on Mercury motors, there is no substuite for Mercury manuals part number 90-25500
