jze1212
- Joined
- Feb 11, 2006
- 156
Hi there. I have got a 1988 100hp I-4, serial# OB312239, running with a hose hooked up - take a bit to get started then will run smooth for a couple minutes, then the idle will sort of "stumble" and it will backfire and throw a puff of smoke.. The it will catch itself and run smooth for a few seconds and repeat. When you hit the gas it seems very responsive and when the motor speed is slowing down you seem to get more little backfires and "pops" than normal? Maybe this is normal for this motor? I have replace the plugs, wires seem ok, compresssion is 110-115 (give or take) .. Any suggestions? I havent run it in the water yet, maybe just needs a good running? I just dont want to mess anything up! Thanks in advance...
