2002 Yamaha fuel line disconnects
Lite 1
I've been told by the dealer of my 02 Yamaha 150HP<br />carb 2cycle that the manufacure did away with fuel line disconnects because of problems with burnt pistons. I would like to use disconnects to add portable tank to increase milage range. Any information would be appreciated.
durk187
Re: 2002 Yamaha fuel line disconnects
Why cant you use a regular gas tank with a spout. There a heck of alot cheeper (4.00) at wal-mart, and you dont have to buy any additional parts. Just pour in the gas tank.
Lite 1
Thank you for the reply but I had two 12 gallon tanks in mind. I don't know of a pour spout for these tanks and they are a little hard to handle in a sea. Is there any truth to the burnt pistons from quick disconnects. thank you.
Forktail
Ensign
Most outboards this size don't use quick disconnect fittings because they go on boats with built-in tanks. If I recall, my older one's don't have them either.<br /><br />Burnt pistons? Nah. The little outboards would be burning pistons too if air entering was the problem.<br /><br />You could always just put a simple male and femal quick disconnect fitting(s) in line somewhere.
seahorse5
The reason that quick-disconnects could cause engine problems is that the small holes in the connector pin limits the amount of fuel flow. On a higher horsepower motor, the fuel restriction would be so great that the motor would be running lean at full speed, and you know what that means!
taz33911
Sounds like you need a bigger tank. lol. but seriuosly how about put a t in the line with cut off valves on both ends . Then you could take the other tanks out if you don't need them. cutting off the valve to the small tank and taking off a hose clamp don't take that much time.
