Marine Batteries - what should i buy?
tyler
I have a 90hp yamaha and need to get a new battery + maybe a backup battery for emergencies... what type is the best for me?
lonewolf5347
Re: Marine Batteries - what should i buy?
they say no to maintence free batterys for outboards
tyler
please pardon my ignorance,,, but what does "maintence free batterys for outboards" mean.... <br /><br />is the dual cycle starting what i need or should i go with a heavy weight commercial for safty..<br /><br />do not want to be caught out fishing and not be able to restart....
MercilessMike
I am no expert on this subject, but her is my 2 cents. Maintenance free usually means, sealed, no routine adding of water. There are two types of batteries for marine, deep cycle and cranking, cranking emit higher output over short term, deep cycle like to be slowly dischared and charged, trollong motors steros accesories and such. When I bought my first boat had 2 deep cycles, then went with a dual-pupose battery. Now i will have 2 seperate batts. 1 cranking 1 deep cycle. However new technology is everywere, the make AGM batteries, expensive, but can be mounted upside down if needed, are totaly sealed so no acid spills. So do you have alot of acc. that would be in use...Fishfinders and such, and how much draw as far as current. 1 good thing about a 90. You can always rope start it. IT CAN BE DONE, trust me on this one. Whatever you do just get a quality battery and a trickle charger to keep it in optimum condition. Most of this info came from West Marine pages on batteries, Other marine batt manufactures have websites to help you decide what you need. Was also told nothing below 1000 CCA. Perhaps others will reply with more info, but Hope this helps, even if it's just a little bit of help!<br /><br />Yo HO HO ...
yensid
Personally, I like the dual deep cycle/starting batteries, because they have a good output for starting, plus can be charged and discharged a lot for the accessories.<br /><br />One note, make sure you keep them topped off with water! I forgot to do that, and it's a pain in the butt.<br /><br />And, having a backup is definitely good!
