Anyone want to Rebuild my Yamaha Carbs for $$$
John from Madison CT
Hi guys,<br /><br /> I was going to try and rebuild the carbs on my '89 Yamaha 90hp OB. The lowest cylinder doesn't seem to be getting gas since the spark plug is clean as new all the time. Granted, I've never run this motor off the motor stand as I bought it used, but nonetheless I don't think it would hurt to rebuild them and try.<br /><br /> Any of you OB Tech guys want to take it on for some money. I would take them off and sent them to you.<br /><br />Let me know.<br /><br />Thanks,<br /><br />John
seahorse5
Re: Anyone want to Rebuild my Yamaha Carbs for $$$
Half the job of a good carb repair is the checkover of the motor, the adjustment of the oil injector (if equipped), the synchronization of the linkage and throttle plates, idle timing, idle speed, carb needle adjustment, and thermostat operation. That can't be done by sending carbs to someone by mail. Find a local QUALIFIED tech to do the complete service or call Yamaha customer service for a recommended dealer.<br /><br />Because you bought it used and haven't run this motor, you should have the tech check it over from top to bottom.
Mikael-Block
hi<br />A clean plug...might be water in cyl.<br /><br />have to be checked allso...<br /><br />Mikael
araiha
John,<br /><br />there is a place down in Niantic that has high yamaha volume. Their address is 133 East Main St. (860) 739-6251.
Thanks guys, I was just hoping for a cheap way out. (as usual, you'd think I'd learn.)
