9.9 Yamaha or honda question
billy-bobby
I'm considering buying a new 9.9 Yamaha or honda 4-stroke. someone told me that I get get a few more hp by getting the exhaust port modified. does anyone know about this , and can you tell me what it entails and what effect that will have on fuel consumotion, noise etc..thanks<br />also, I am thinking about the 9.9 two-stroke Yam.<br />any opinions offered on their 2-stroke?
Mr.Bill
Re: 9.9 Yamaha or honda question
If you can swing the extra money the Honda 4 stroke is the only way to go!!!!!! I personally do not like the Yammys Dont buy a 2cycler to much pollution to load not as much torque.Remember -HONDA- has been building 4 strokes for a long time and has buy far the superior product.
I would definately look at the four strokes. I have a Honda 8hp that is great!! No oil to mix, very quiet, they run forever very clean and many will also charge your batteries while they run. I have some buddies that swear by their yami 4 strokes so I can't say any thing bad about them. If you are looking at a new motor the 4 stroke is the way to go.
digimortal777
we used to own one of those yamaha 15's!!!<br /><br />awesome motor ran great
Forktail
Ensign
Modifying a 9.9? I thought this was a joke, but I'll bite anyway. :) <br /><br />Any performance advantages in modifying the exhaust valves or the exhaust ports on a 4-stroke 9.9 is overcome by expense. Hardly worth messing with it. <br /><br />2-strokes can gain additional hp by modifying the exhaust ports. But this usually means modifying the tuned exhaust system, the rest of the cylinder transfer ports, and increasing carb jet size as well. Your upper rpm will increase and usually you will lose some lower end torque. Noise will be related to the tuned exhaust system modification. Fuel consumpiton may or may not change, it all depends on the engine and its use. Your chance for a lean condition (detonation or burn down) increases. The chances of increasing a 9.9 hp by a few more (to 13 hp) with just an exhaust port mod is unlikely.<br /><br />The engine would have to be disassembled and the cylinders would have to be modified using a tool similar to a dremel tool. Transfer ports get enlarged, smoothed, and re-chamfered. Porting is usually done by experience, and can really screw up an engine if done improperly.<br /><br />The only advantage the 2-stroke Yamaha would have over the 4-stroke Honda is 10 lbs and less initial cost. But it only comes in a 15" shaft. The Honda and Yamaha 4-stroke 9.9's come in 15, 20, or 25" shafts.<br /><br />"Remember -HONDA- has been building 4 strokes for a long time and has buy far the superior product."<br /><br />Honda makes good stuff, but "superior" is your opinion. I own several Yamaha 9.9 4-strokes that I wouldn't trade for a Honda if you paid me. I swear these little Yamaha's are made by a Swiss watch maker.<br /><br />Some points of interest between the Honda 9.9 4-stroke and the Yamaha 9.9 4-stroke:<br /><br />The Honda uses a 222 cc block, the same as the smaller 8 hp.<br />The Yamaha uses a 232 cc block, unique to itself.<br /><br />Honda only adds a 4-blade prop to their 9.9 to get their 9.9 "Power Thrust" model.<br />Yamaha uses a different gear ratio, operating rpm, and a dual thrust prop for their "High Thrust" model.<br /><br />The Honda is more expensive.
Bear
Forktail, for what it's worth. I do agree to all that. I was thinking of the previous 8 and 9.9HP models. This third generation is way too expensive compared to the Yamaha. The general opinon around here (if there is one), is that the Yamaha 9.9Hp is one of best 9.9 around. Or the best choice. But I still like these Hondas. :)
billy-bobby
thanks for the opinions. By the sounds of it, it's a toss up as far as either honda or yamaha.<br />obviously , there are fans of both out there.
