Re: Dual Battery Connection
Run the motor on battery one, next time out run motor on battery two. To play it safe you could start on one battery let it warm up, turn it off and start on the other battery. Now you know both batteries will start motor. If you do not use the boat for long periods of time use your charger one battery at a time. I do not charge my bateries unless the boat has not been used for several weeks. I do not run my motor with selector switch on both.
