The problem that I am having with my Yamaha is on cold starts. When you turn the key you can hear what I think is the starter engaging (click, click, click, click) and nothing happens. After a few trys the engine will fire up and run perfectly. Once the engine has started running it will fire up all day long without a hitch but when you let it sit overnight the same thing happens all over again. I thought that the battery was losing a charge when it sits for long periods of time. So today I went and bought a new Stowaway battery and installed it. The same thing happened but I only had to turn it over 2 times before it started up. Could the new battery not of had a full charge from sitting on the shelf?? If not then I wonder what the problem could be.
