Suzuki DT55 question
Kangaman
Hi everyone..<br /> <br />I've recently purchased a boat with a 55 horsepower Suzuki DT55. The motor runs fine but the pidler (not sure the exact name for it, its the little hole where water sprays out) doesn't always seem to be spraying out water. It's been recently serviced and the mechanic says everything is fine. <br /> <br />Should water always be spraying out and if so, always at the constant rate ?<br /><br />Cheers<br />Kangaman
Joe S.
Re: Suzuki DT55 question
Water should definitely be coming out. Either the pisser is plugged or you need a new water pump impeller.
Kangaman
Thanks Joe, i've just had the impeller replaced and it came out hard for a little while but now it only trickles out.<br /><br />back to the repair guy
fridays
The pee hole on Suzuki's (and many other brands) are too small and get plugged easily. Take a small drill bit and drill the hole in the little plastic fitting out to a larger size. Blow it out acouple of times to clear the tube and get it the habit of FLUSHING your engine after use.
Kangaman
thanks for the tip, i'll try it out.<br /> <br />i'm a boat newbie..
