jim dozier
Thread starter- Joined
- Jan 8, 2003
- 1,970
I have recently fixed an overheating problem on my 87 Suzuki 85hp which required cleaning the cylinder head and a updated modified head gasket. To help monitor my engine I wanted to install a gage. A search on this forum turned up some discussion on benefits of a water pressure gage versus a water temp gage. I am still not clear on this. Many of the pressure gages seem to be hooked up to the pee stream. I thought thats what the pee stream was, a visual check of the water pressure. If I have a good stream why do I need a gage attached there? This begs another question. Is there a better place to put the pressure gage-pickup? Anybody know the best place on the suzuki? There is a metal threaded plug on the cylinder head, should it go there? And another question. What keeps air from getting in the system and collecting at the top of the head/block in the thermostat area and if it does is that a bad thing? Seems like it would be. Or do I just get a cylinder head temp gage with a sender that bolts to the head with the head bolt and go boating?
