I have a Yamaha 40 Hp Outboard that ran great Last year. This year it starts and idles fine but at full throttle it gets bogged down and will not plane out or output to it's capacity. After removing the cover and playing with the Choke we found the boat Ran great with the choke in 2/3rds at full throttle.(Got up into the middle 30s as opposed to the 8-10 it was running before. What adjustments should I make? I didn't want to adjust the choke so that it is only a third open when set to full open. Would I want to adjust the needle valves on the carbs? Is it just getting too much air in the mixture? Should I go to a higher octane gas? Any help would be appreciated as I am not real familiar with outboards. I do know that I can't cruise around the lake with a buddy holding the choke 1/3 out all the time. Thanks in advance.
