1989 Suzuki 140 stuck in high rpm position???
philtheskipper
Just tried to start this motor for the first time(ever) and it starts fine but is racing at what seems to be wot. When I move the throttle lever all the linkages that run to the carbs seem to be moving right, but I know nothing about outboards. Can you guys point out a few things for me to check?
outboardjake
Re: 1989 Suzuki 140 stuck in high rpm position???
Disconnect the throttle and shift cables. Remove the airbox cover and check for forign objects. Mice kind of like airboxes. Make sure the throttle plates are closed. Give it another try.
philtheskipper
I had the previous owner take a look at it and he fixed it. He had taken the motor off the boat and when he put it back on he didn't adjust the throttle cables correctly. I'm ready for the open water!!! :D Thanks for the reply Jake.
