FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
When I put ear muffs on it it will blow out water through the hole but when I go out on the lake it doesn't work. The pump is fine though. What is wrong???
Re: Suzuki 85 HP water pump blows out air but not water
justboatin<br />If it is an 87 model, I feel for you. <br />Look at my post and you might get some place <br />to start looking.<br />(87dt85 still overheating)<br />There is another compodre by the name jimd<br />who also has the same motor. <br />You may want to look at some of his posts.<br />We have been doing extensive research and throwing money at thease motors to no avail<br />I hope you have better luck than us.<br />If you do please post it for us poor slobs.<br />Did you replace the impeller? <br />Did you check the gromets on the metal water pipe <br />between the pump & powerhead?<br />Did you check the Thermostat?<br />Please tell us more about your motor and what you<br />have done so far.<br />if you hav not allready done it , change the impeller, that should be the first thing to try<br />If it is bad it would cause the problem you describe <br />muffs have enough pressure to flow water even <br />with no impeller
Hmm..not a Suzuki guy but...from the sounds of it I would be looking for a leaking exhaust gasket or blown head gasket.<br /><br />Reason I say this is when you submerge the engine you get back pressure on the exhaust..and a better chance it will find another route to leave the engine.<br /><br />TMD
I have a similar problem with a Suzuki DT 3.5, After replacing the impeller, there's no water coming out of the pee hole, Mostly just air with spits of water, it feels like exhaust. I'll try replacing the rubber grommet around the outlet tube. Any other ideas?
Check that the water entry slot on the pump bottom plate is to the Port side of the gearcase meaning that it takes 270 degrees of rotation of the shaft to move the impeller arm from the bottom plate slot to the the water exit at the top (rear) of pump. if plate is installed upside down slot and exit are in the same place and pumping will not occur. It works with muffs because you have water pressure. If you have a poor water tube connection between pump and powerhead, water can generally be seen leaking from a hole in the front of the leg just above the gearcase.<br />Regards sirlespat
