OK amother try. Can anybody tell me the manufacturing year of my Yamaha
Knientje
Model: 4 AC<br />Serial Number 6EOS 064442.<br />thanks to the one(s) who answer
rodbolt
Re: OK amother try. Can anybody tell me the manufacturing year of my Yamaha
hello<br /> i cannot help you. in the us all the motors are identified with alpha charactors
Anymec
Look at the same place where you find these numbers, there is a character stamped.<br />It's placed at the bottom of the plate on the black part of it. Clean the plate well and you can see it........<br />What is that character??
zzzzz
Thats a 1980..go to modellguide..then Yamaha..scroll down to 6EO :cool:
wtrojan
Wabbit,<br />I recommend you call The Netherlands Yamaha or maybe Yamaha in Germany. I’ve been in similar spot, looking for my motor year for very long hours on internet. Several posts to this forum, calls to local Yamaha and to US Yamaha didn’t help either. If it is not the US model, it’s quite a problem.<br />I don’t think your motor would be exactly the 1980, although the list is good, the year says “1980-“, I imagine that it means it has been produced for quite a long time. As an example, using the same key, my engine would be 1982 and it’s… 1994 according to NZ Yamaha, who were so kind and helped me out. Serial number does matter. So don’t give up and call some European Yamaha dealer.
Captcweed
Don't know if you can find the same info on the plate left side of motor as I did? But the Motor Guide listings in the Forign Motor Index ( read two post's earlier)it is on target to find the year of Mfgr. I found mine quick time.
raymo
hi,as a novice to both boating and the interthingy, may i also seek help regarding the age/model of my yamaha 9.9? does the following make sense to anybody out there ?<br />F9.9AE, 6C8,1 402 121. All replies gratefully recieved,(offside rule, (soccer) explained, or beatles anecdotes in return!)
zzzzz
try the foreign motor link a couple posts up :cool:
