Suzuki Carbs.
TideRunner
I have an 86 DT75 I was woundering if their was an airflow meter used to get all three carbs adjusted after a rebuild or do i just dial them in as close as i can by ear? Thanks
jim dozier
Re: Suzuki Carbs.
The book says to use one to balance the carbs. I have a 1987 DT85 which is a similar setup setup as yours I think. If you have the little plastic adjustable turnbuckles you don't really need the air flow meter. Just make sure that when the carb throttle linkage to the ignition is disconnected, all 3 carbs completely close their butterflies. If not use the turnbuckles that connect all 3 carbs to set them closed. Then set the static ignition timing by the book and you should be good to go.
