propeller problem
nikola1976
Ive purchased a Yamaha 40hp autolube that is in great shape, but the only problem is the propeller, because it is damadged, I cant read the diameter and pitch number from it so I need some help because I want to buy a new one. If someone that owns/owned a motor like this and knows these numbers please answer!!!
rodbolt
Re: propeller problem
hello<br /> could be one of many. there is no standard prop for outboards. remove it and send it to a reputable prop shop and they can tell you what it is. if you are putting this motor on a different hull then odds are the prop wont fit anyway. the motor must be propped to turn at least 5500 with a medium load.<br /> Good Luck and keep posting
