Water Pump
rodbolt
Re: Water Pump
hello<br /> its on the lower unit<br />seperate the lower from the upper and its the big housing held on by 4 bolts with a shaft passing though it.<br /> good luck and keep posting :)
JB
Re: Water Pump
Howdy, WRX.<br /><br />If you need to ask where it is I think you need a Repair Manual before you start.<br /><br />Good luck. :)
rodbolt
Re: Water Pump
go JB :) . that answer was way better than mine
WRX_23Q
Re: Water Pump
How you doing rodbolt?<br /><br /> Thanks mate i appreciate that. I just bought a boat and im not very familuar with where the water pump was.Well with your advice ive changed the impeller and its working fine thanx champ.
fluxbox
Re: Water Pump
I have a suzuki df70t for my 17 foot boat wellcraft, Been sittig for about 6 years.Mortor looks clean.Was woundering water the compreshion all 4 cylender need to be good and bad.Thanks for the help.And i need to change the water pumps i dont think that will be to hard how you do it.I know were it is.And how much would it be.To replace it
