Oil injection removal
paragod
I have a 1986 -87 115 yamaha I want the oil injection off before it has malfunction and blows up the world Thank u !
BRIAN03
Re: Oil injection removal
WHY Yamahas oil injection doesnt fail. It will only over oil never under oil. The system is a gravity feed system to the oil pump. The oil is injected in to the intake manifold. Its a great system. Keep the oil tank and filter clean. I replace the oil pump when the engine has 1000 hrs. or when we do a rebuild. Keep the oil clean and free of water and check you warning system once a year and it will out last the engine. The oil is controlled by throtle position. You use less oil with the system in place.
paragod
ok if u think thats best one of the guides I fish with just blew up his new 2002 v-max Yamaha said oil pump failure He has a new warranted power head now.Thanks for the help I will take it in and have it serviced to make sure all is well.
BRIAN03
Yamaha will fram it. NO WAY You need to find another dude working on your stuff. Still NO way.
brentg
I have a 40 hp 2cycle 1986 unit, the oil pump is stuck in full open and the throttle linkage is attached to the oil pump. When I attempt to start the engine is in full throttle. So I shut down right away. I was thinking of removing the oil pump and pre mix the fuel. or should I disassymble the old linkage and leave the oil pump on.<br /><br />Brent
