One last wire
blitzen2
Well i swapped my 1990 oil injected 115 over to a 2000 non oil injected without much trouble everything hooked up just like rodbolt said except i'm left with one wire which braches off of the big 10pin connector right at the connector located on the motor side. Its gray with a black line anybody got any ideas?<br /><br />Thanks
phatmanmike
Re: One last wire
im new to this , but could it have anything to do with not having oil injection anymore, maybe a low oil level sensor or something along these lines?
rodbolt
Re: One last wire
hello<br /> I cant remember off the top of my head but I think it was for a visual alarm indicate.let me see if I can look around and I will post back <br /> good luck and keep posting
blitzen2
Re: One last wire
Ok, Thanks for the help guys let me know if you find something rodbolt because i really want to start this thing but dont want to short or create problems leaving this one last wire unplugged. If anybody else knows lets hear it.<br /><br />Thanks evrybody
blitzen2
Re: One last wire
I traced the wire into the cdi unit and out of the cdi to the temp sensors on the heads so what do you think it hooks up to? The buzzer? Or is it power in maybe?<br /><br />Thanks :confused:
rodbolt
Re: One last wire
hello<br /> yep its a wire for a visual indicate for one of the multifunction gages.if your meter has the capeability then it will have a gray bullet connector at the engine end of the 4 pin trim harness. if it does not then secure it out of the way and go boating.<br /> good luck and keep posting
