I have a Yamaha F100 that has suddenly developed a annoying problem. When I tilt the engine all the way up to trailer the boat the unit will not power back down. You must release the pressure release valve to get the motor down. Once down the unit works fine. It does not leak down and performs as designed under normal situations. I have checked and changed the fluid, bled the air with no effect. It only hangs if you raise the motor all the way up. Any thoughts or tricks to try. Thanks in advance.
