Re: 94' Suzuki dt 115 no power when under load
OK!!!!, Here's the scoop..... After further reveiw and alot of hours last night and this morning, I narrowed the problem down to the oil flow sensor, weird because it checked out earlier. I put the boat in the water and ran it, and diconnected all the sensors. She ran fine, I put each one back on till the problem came back. Here the flow sensor was causing my dilemma. I want to thank the forims for all the info I got...(RE:... Mixing a small tank of 50:1 as a precaution before running the motor).I am cleaning the oil lines and the tank and should be my problem. I also have a little bit' of mid range surge, I am going to place that on carbs!! I think a little b-12 and a good cleaning will take care of that.<br /><br />But all in all, this is my first Suzuki engine,and what a learning experience!!! All she wanted to do was run today!!!! I ran her up amd trimmed her out she gave me 43+ MPH and I ran out of lake!!! She still had more to give me. I am very pleased, all the posts about the Suzuki electronics being solid is correct!!! Well I am off to clean those oil lines and carbs. I will post back let you all know of any improvement.<br /><br />Thanks again,<br />Matt K
