Hi,<br /><br />One of the two 1997 Yamaha 2-stroke 200 HP Saltwater Series engines on my 25' Grady White Sailfish overheats and powers down. My marine mechanic has replaced the water pumps, removed the thermostats, and removed the heads and check for water passage restriction (there was none).<br /><br />He said he put a laser on the engine and knew that it was hot, and therefore not a sensor.<br /><br />He seems lost for an answer and I am getting concerned. He suggested taking off the powerhead and inspecting it for a leak in the water tube(?). Is this the direction to go?<br /><br />By the way, Rodbolt - you are a legend on the Continuouswave.com (for Whaler enthusiasts) forum.<br /><br />Thanks
