Re: Please help for the right prop
To answer your rpm question, thats absolutely normal to get the rpm change with a pitch change. Though in your case with two inches the rpm dropped by 700, and it is a lot. Usually thats about 400rpm change with 2 inches of difference in the pitch.<br />You should get the pitch which allows you going at max rpm with regular boat weight, at WOT. You should not let her go more max rpm that allowed, and going WOT and getting less rpm than max is not healthy for the engine.<br />However, the performance will depend on the setup you are running and all this is assuming that you are trimming the engine properly and that everything else is ok, like the height of the engine on the transom. The height of the engine may be worth checking - as a general guide the anti-cavitation plate (the biggest plate on lower unit) should be in the range of one inch below to one inch above the keel, the latter being the good point to start the transom height tuning. The lower the engine on the transom, the higher the drag.
