new2obrepair
- Joined
- May 16, 2004
- 35
I posted some time back on my overheating problems on a 1984 yamaha 15hp 2-stroke. model #15SN. So far, I have changed and rebuilt the water pump, changed the head gasket and the exhaust gasket, put in a new thermostat, and worked on water jacket, rebuilt the carburetor, had some debris and small stones in water jacket. I just discovered the water inlet strainer has been destroyed, only fragments left. But I thought I would have flushed any debris out of the head and lines. I also found the pick up tube had a rubber boot that was pushed over the end of the metal tubing about 3/8". So I trimmed that off thinking it was folding over under pressure. Put motor back together, and ran in tank of water. good pee stream at idle, sputters and stops by 1/3 throttle. Any ideas?
