tilt/trim one piston or two?
richg99
I recently asked about a perceived tilt/trim problem. I am now lead to believe that my engine ( used, bought at a very good price ) might only have power tilt, but not power-trim capabilities right from the factory. If so, that is OK ( I have Smart Tabs and the boat trims out fine without any action needed from the engine) but does a TILT ONLY engine only have one piston and a t/t have two pistons??? thanks RichG
JRJ
Re: tilt/trim one piston or two?
My Suzuki/Johnson has only one piston and tilts/trims just fine.
richg99
Thanks, JRJ...only that blows the theory that I could easily PROVE what I have. I'm still confused and will proceed with contacting Yamaha directly to find out what I actually own. RichG
richg99
Well,.... mystery solved. The 40 hp Yamaha '96 does NOT come with power "trim" just power "tilt". My thanks to the responder who posed this possibility. <br />Anyhow, after actually reading the manual ( which I was given when I bought it, but had mis-placed) it described how to try different settings with the pins on the motor. I moved one pin manually, and the performance increase was substantial.<br />My thanks to all who tried to help. RichG
