Yam 225sx power loss
jdunc777
I have a 2000 yam SX225TRY, at 4000-5000 rpm the engine bogs down/ stalls, I have good fuel supply to the fuel pumps so maybe fuel pumps, carb's, or a electrical problem? I 'd like to rule out the electrical problem.<br />thx
jdunc777
Re: Yam 225sx power loss
Never mind, 3 new fuel pumps did the trick.<br />I'm putting three new ones on the starboard side also. Took about 1 hour to change them out. Runs nice at WOT.
rodbolt
like i say on a yammi every 3 years replace the fuel pumps. at least once per year clean or replace the VST filter. on the hpdi motors every 200 hours or yearly for the medium pressure filter.<br /> clean filters are the key.<br /> good luck and keep posting
jdunc777
rodbolt, I have manual in the mail as we speak, where is the VST filter and O2 sensor.<br />Thx
jdunc777
Also, I saw you talking about,<br />Vapor seperator sensor<br />T-stat's<br />pressure valves<br />poppets<br />And the carbs, how long till a rebuild or can I treat them w/ anything to prolong thier life w/o rebuilds.<br /><br />thx
rodbolt
hello<br /> the vst filter is located in the tank on the port fwd side of the engine. remove the screws and the 3 bolts that hold the tank to the crankcase and you can access it. its expensive.<br /> the O2 sensor takes a 22mm o2sensor tool to remove. I always remove the holder from the block as well.<br /> the O2 sensor is located on the portside hih on the #1 cyl. it has a black plastic cover and 4 small wires.<br /> you will need a gasket kit to clean it.<br /> you have no carbs. its injected.<br /> good luck and keep posting
rodbolt
opps<br /> O2 sensor is on the stbd side:) :) <br /> its early and left and right is difficult :) :)
RodBolt: <br /><br /> I have to try and clean my VST Filter too on my '98 250hp Ox66. I get a hesitation when the boat hits a wave/wake.<br /><br />How do I de-pressurize the VST ????<br /><br />Also, if I understand correctly, the screws that hold the "tank/resevoir" part and those that hold the VST to the block are the only things necessary to remove. Is that correct??<br /><br />Thanks for your help.<br /><br />John
rodbolt
no need to depressurize anything. yes the phillips headed screws that hold the resevoir in place and the 3 6mm bolts that hold the tank to the block<br /> good luck and keep posting
