R_Andersen
- Joined
- May 3, 2004
- 78
I have a boat with twin 1989 DT 200's. The boat sat for about 4 years before I got it but the motors had been properly winterized when it was put away. I have since changed the impellers and have both motors runnign again.<br /><br />The problem is that both motors run great in neutral and will idle perfectly all day long in gear. As soon as you accelerate above idle, both motors want to die. They just bog down and shut off. If I rev up both motors in nuetral and as soon as they come back down to about 1200 rpm, put it in gear and accelerate hard I can usually get both motors to stay running and then the boat will run fine above 3800 rpm. I drove around for about an hour and had no problems at all as long as I stayed above 3800 on both motors. As soon as I slow down to below that rpm, both motors bog down and stall out. They will both then restart immediately and idle perfectly again. <br /><br />I ordered carb kits and am going to rebuild the carbs but it seems odd that the motors will idle fine and run fine over 3800 rpm, but will stall out at anything in between there....<br /><br />Any advice would be appreciated.<br /><br />Thanks,<br />Rob
