Re: Yamaha Oil Injection Problem
OK, I bought the boat at a dealer on consignment. So they are working with me on the issue. They called me today, and told me that the CDI unit that they installed yesterday tests out bad. Have u guys ever heard of a part like that DOA...?? They are ordering a new one and will try another one next week. Yamaha tech support appently told them to test the unit.<br /><br />THe other thing that I was thinking is that I am not using the Yamaha gauges. They are Teleflex. Would the open connector inside the motor for these gauge warning lamps affect the system to not work?<br /><br />At this point im hoping the CDI that thye had was bad and another one will do the trick....<br /><br />I know all of you are busy,,,but is there an order of test procedures to go over again if Im still down... If you could type up a list of test procedures to try that would be great.<br /><br />Here is a summary again of what its doing and what was done so far....<br />1 Motor is using oil...The motor mounted tank will hit the low level line and the buzzer comes on. Will not send oil from boat tank automatically.<br />2 Manual switch DOES work....<br />3. Motor tank sensor unit is replaced.<br />4. Boat tank and sensor, pump is new last year.<br />5. CDI with the oil control module was replaced, but part supposedly is DOA...<br /><br />6 Will try new CDI next week....<br /><br />Thanks!!!! for all your help...Rodbolt thanks for yoru expertise,,,,,
