Dissappointed with gas mileage, any advice?
JJ Bones
I have a 1991 Thunderbolt bassboat (17'8") which weighs about 1180lbs. dry with a 1991 Johnson V-6 150 horsepower. I have a 20 gallon gas tank and it only lasts about 15 miles (estimate). Granted, I like to generally drive fast, rpm @ 6,000 (or at least that what the meter says). I have a jackplate and stingray foil attached. I recently had the motor tuned-up which included a carb cleaning. Could this be right or it there something I can do to increase range? Do some of you bring extra gas along in a portable tank? Any ideas or suggestions would be appreciated.
JRJ
Re: Dissappointed with gas mileage, any advice?
A 4000 rpm cruise will help properly trimmed. A 150 4stroke or EFI 2stroke will really increase your milage. Maybe tow a fuel barge? Good luck and welcome to iboats :D
Dhadley
Welcome!!<br /><br />Which 1991 150 do you have? The crossflow or the 60 degree looper?
JJ, You have four choices (or combinations of these). <br /><br />Use a higher pitched prop, if it will still allow you to get into WOT range.<br /><br />Make sure the Stingray is out of the water when you are on plane, so it doesn't drag, or remove it.<br /><br />Trim boat to achieve max speed.<br /><br />Back off just a bit (10%) from WOT. You will go nearly as fast, but save a lot of fuel.<br /><br />Failing these, get a bigger gas tank and another credit card.
Mischief Managed
There is something seriously wrong of you can only get <1 MPG with 150 HP driving a 1200 lb boat. I'd find out where the gas is going cause it's not making HP.
QC
I'm with MM.
JJ Bones
The motor is the crossflow ... the prop is stainless with four blades ( I,m not sure exactly what size or pitch it is). What is WOT? I do not have a trim gauge ... how do you know when you trimmed up too high? I am definitely going to take the stringray foil off and try without.
navigator336
You definitely don't need the Stringray foil with that engine and boat weight. WOT = wide open throttle. The engine manual whould state what RPM's should be reached at WOT. If you are getting less, use a lower pitch prop. If you are able to exceed the recommended WOT go to a higher pitch prop. Trim is generally optimal (on relatively calm waters) just before the boat starts to porpoise (the bow is going up and down).
QC
navigator's advice is correct although I will add that if the boat is bow heavy, the RPM may start rising rapidly at high trim and speed levels before she will porpoise. You'll know when this happens . . . ;)
jlinder
I don't know what the WOT (wide open throttle) should be, but 6000 RPM for an I/O with a 6 cyl. engine sounds awful high. What would redline be for this engine?<br /><br />I find maximum economy occurs just after the boat gets on plane. After that I get more speed, but sacrice economy.
QC
Jack L,<br /><br />It's an Outboard Johnson unless you're talking about your engine?
BTF112989
The WOT for my engine is 5000-5500. It is a 2001 Yamaha 150 HPDI. So yours should be around that general area. And if you are at 6000 RPM's all the time no wonder your gas doesn't last you long. I usually go 5300 at the most. I just don't want to push it.
BTF112989
Pony
Originally posted by BTF112989:<br /> The WOT for my engine is 5000-5500. It is a 2001 Yamaha 150 HPDI. So yours should be around that general area. And if you are at 6000 RPM's all the time no wonder your gas doesn't last you long. I usually go 5300 at the most. I just don't want to push it.
Yeah 6000 may or may not be right...I dont know but others here or your manual will.........<br /><br />BTF- He may be burning more fuel at WOT as all engines do.......BUT regardless of that fact 20 gallons in 15 miles is WAAAAAY to little. <br /><br />Its my understanding that on avg a 150hp motor will burn roughly 15 gallons of fuel per hour. So a 20 gallon tank should last a little over an hour, like an hour and 20 min or so.......using 30mph as a VERY CONSERVATIVE mph, that tank should yield 40 miles. IMHO
BTF112989
I am lucky that I have a 62 gallon tank on my boat. I am usually more concerned with my fuel going bad because I don't run enough to use 60 gallons of gas every outing. They put huge tanks in ocean going boats.
steelespike
If your motor uses a typical outboard fuel pump<br /> it may have a hole in the diaphram letting gas leak into the crankcase.<br /> If you run your motor at 6,000 rpm most of the time I think besides using a lot of gas your using a lot of engine life as well.
